Enables MAC locking globally on the switch.
MAC locking is disabled by default.
To enable MAC locking on a specific port, you must enable MAC locking on the switch and on the port. Use the enable mac-locking ports command to enable MAC locking on a port.
The following example enables MAC locking on the switch.
enable mac-locking
This command was first available in ExtremeXOS 15.7.1.
